Writing data from PLC to XLS file
I am trying to write data from a PLC to an XLS file, i can write data when its generated, but wheni read from a DataSocket i cant seem to write it to the XLS file...
i have attached what i've done please let me know what you think...
any corrections and or suggestions are welcome..
thanks,
-U
(2,723 Views)
I wasn't able to see the diagram of your VI. What I suggest you do is to simplify the problem and make a VI which does not involve the OPC Server, for example. Simplify it to a point where the problem can still be reproduced. And then share the VI with us. We'll be in a better position to hel you then.
Khalid
(2,723 Views)
