Remove NaN
How do i remove the NaN in "output/input" array. Also i need to display the top column of "200077670" array like "2000776729".
Message 1 of 40
(21,523 Views)
When you divide a 0 by 0 it will give you NaN. Check the values coming in the denominator is a non-zero value since you are trying to calculate percentage (I Guess).
Good Luck.
Message 2 of 40
(21,510 Views)
Some of my denominator has values. Is it possible to display it in "0" instead of NaN for both non values and with values?
Message 3 of 40
(21,486 Views)
yes you have to check the values as NaN if true pass 0 else pass the value. You can perform this inside the for loop.
Message 4 of 40
(21,481 Views)
something like this?? not very good in this...new to LV
Message 5 of 40
(21,466 Views)
I use this to remove NaN from my arrays, hope this helps.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 6 of 40
(21,459 Views)
Thanks Smiley Happythat was good but i am required to show the "0" array instead of removing itSmiley Frustrated
Message 7 of 40
(21,456 Views)
well then just replace the "delete from array" primitive with a "replace array subset primitive" or better with an inplace structure.
Epictetus
Antoine Chalons
Message 8 of 40
(21,451 Views)
Accepted by nyp123
I generally use the following method. 1st one replace the NaN with 0 and the 2nd removes the NaN.
Good Luck.
Message 9 of 40
(21,442 Views)
you'd be slower on large arrays 😛
Epictetus
Antoine Chalons
Message 10 of 40
(21,439 Views)
