Remove Overlay Line
Hi everyone,
I created a circle, and every time you press a button next, I overlay a different line on the circle,  I want when you push the button, that a new line appear (that works fine) but i need the previous line dissappear every time you push the button, so there is one line at the time. How can you remove the previous line when the next line appear?
Henk
(4,560 Views)
Please explain how you are drawing circle and doing overlay. If possible please attach the code (in 2011 version) for a better solution.
(4,537 Views)
I use LV 2010, see this topic to see how i did it:
http://forums.ni.com/t5/LabVIEW/Fit-a-line-into-a-circle-based-on-centrepoint-and-angle-in/m-p/30583...
I put the start and end point into IMAQ overlay line,
Tnx,
Henk
(4,531 Views)
Is that enough information?
(4,472 Views)
Accepted by henk_kempen
Did you try using IMAQ Clear Ovelay?before redrawing new ovelay.
uday
(4,458 Views)
I did not, but I should have:), tnx  a lot, I am ashamedSmiley Embarassed
(4,453 Views)
No problem, we all are not born with intelligence...there is nothing to be ashamed 🙂
uday
(4,450 Views)
