Remove Overlay Line
Hi everyone,
I created a circle, and every time you press a button next, I overlay a different line on the circle,  I want when you push the button, that a new line appear (that works fine) but i need the previous line dissappear every time you push the button, so there is one line at the time. How can you remove the previous line when the next line appear?
Henk
(4,934 Views)
Please explain how you are drawing circle and doing overlay. If possible please attach the code (in 2011 version) for a better solution.
(4,911 Views)
I use LV 2010, see this topic to see how i did it:
http://forums.ni.com/t5/LabVIEW/Fit-a-line-into-a-circle-based-on-centrepoint-and-angle-in/m-p/30583...
I put the start and end point into IMAQ overlay line,
Tnx,
Henk
(4,905 Views)
Is that enough information?
(4,846 Views)
Accepted by topic author henk_kempen
Did you try using IMAQ Clear Ovelay?before redrawing new ovelay.
uday
(4,832 Views)
I did not, but I should have:), tnx  a lot, I am ashamedSmiley Embarassed
(4,827 Views)
No problem, we all are not born with intelligence...there is nothing to be ashamed 🙂
uday
(4,824 Views)
