Remove from Table
Hello all. I have a listbox that i am using to design cycles and add cycle steps to a table. If i make a mistake i can clear the whole table by reinitializing to default value. My problem is that i cannot figure out how to remove the last step in the table. Any help is Greatly appreciated.
Mike
I have attached my main vi. just delete the two subvis and it will run fine.
Message 1 of 11
(5,568 Views)
Greetings GRMAN ,
I downloaded your VI and tried to open it .. but it doesn't open ( I don't mean opened with errors .. No .. It doesn't opened !)
Message Edited by Ayman_Metwally on 01-03-2006 05:42 AM
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
Message 2 of 11
(5,560 Views)
Hi Mike,
Not able to download/open your VI.
take a look at this VI.
Here i am initially building a table and user can remove the current the last row inside a while loop
regards
Dev
Message 3 of 11
(5,552 Views)
I am also unable to download your program.Just see Attached program.
Hope it helps !
Message Edited by Vikask on 01-03-2006 06:02 AM
Message 4 of 11
(5,551 Views)
Hi Moderator,
This is the second attachment that is behaving like this
This mail also had the same problem
http://forums.ni.com/ni/board/message?board.id=170&message.id=158868
On one attempt to download, it asked me to download some software/exe, a pic of which i have attached.
Regards
Dev
Message 5 of 11
(5,549 Views)
devchander -
I'm unable to reproduce the problem you are having downloading attachments in the forums.  Is anyone else seeing this behavior?  Do you get this message with every file you try to download from the community or just on these two threads?
Thanks!
Molly K.
Web Support & Operations Manager
Message 6 of 11
(5,528 Views)
Molly,
I can open it in LV 8. LV 7.1.1 fails to open it and does not give any error. Usually attempting to open a LV8 VI in LV7 produces an error saying the VI version is later than the LV version.
Lynn
Message 7 of 11
(5,519 Views)
Mike,
I have modified your VI to use the Event Structure and eliminated local variables. So that I could test it without the missing subVIs, I deleted the case structure in the Add Step case. I could not tell what it was supposed to do. However, with fewer cases than items in the listbox, it created what I thought were unexpected (from a user's ppoint of view) results.
Lynn
Message 8 of 11
(5,499 Views)
Molly,
        Not for every attachment but for 10% attchments I face this downloading problem.The downloaded vi behaves as if it is subvi and LabVIEW starts searching downloaded vi itself.
Message 9 of 11
(5,480 Views)
Molly,
Yes, I observed this with only these two atttachments.
Usually,if it was saved in a higher version( LabVIEW 8.0 in this case) than a version installed on my system, i would get a relevant message.
But in this case, i experienced the previously explained problem
Regards
Dev
Message 10 of 11
(5,479 Views)
