Remove number unit in Format into String
I want to send a String command to a VISA resource. On the UI is a double input field "amplitude" with unit volt. When using the "format into string" function, the unit ends up in the string send to the VISA device causing an error there:
Probe "5" always shows a string like "AMPL nn.nnn V;"
What would be the most elegant way to get rid of the unit?
(1,757 Views)
Accepted by wgeithner
Hi wgeithner,
remove the unit by inserting a ConvertUnit function before the FormatIntoString…
(1,754 Views)
