Remove retrace path in XY graph
The attached VI is an implementation of output characteristics of a transistor. I have implemented using basic equations. However, my problem is that the XY graph retraces to 0 and then starts for a new value of VBB. I dont want that retrace path. By this, I mean is that as soon as the completion of the inner loop the outer value is updated. Since the inner loop starts agains with 0, I dont want the line from the last iteration of the inner loop to the new interation of the inner loop.
How can I remove that. Please help
(3,190 Views)
Accepted by Jay.kothari
Insert an extra point containing NaN into the data, it will break the line.
(3,180 Views)
I did not understand it clearly. Where to insert and how to insert. Can you please if possible modify the VI and help me.
(3,177 Views)
Here is a quick draft.
I would recommend to use complex data for the xy graph, it dramatically simplifies the code.
(Some other points: don't use while loops as for loops. Since you know the number of iterations before the loop starts, a FOR looop is correct. Use the correct data types for diagram constants. There is a primitive for "+1")
(3,174 Views)
Got it.. Thanks a lot.. U are a champion indeed, Sir. Thanks a bunch 😄
(3,173 Views)
Can you tell me why did you add the Re/Im to Complex part ?
The VI rocks. Hats off to you.
(3,169 Views)
XY graphs accept many types of data. Cleanest is complex data, where it simply graphs IM vs RE. All you need is a single 1D array instead of more complicated data structures.
Some of the possible datatypes for xy graphs are listed here:
  1. A cluster of an x-array and a y-array.
  2. an array of such clusters. (for multiple plots)
  3. An array of clusters containing two scalars for each point
  4. A cluster array, each element containing and array of clusters as in (3)
  5. A complex array (graphing RE vs. IM).
  6. An array of clusters, each containing a complex array (multiple plots).
  7. etc.
(see also)
(3,159 Views)
