Remove string from txt file
Hello guys,
I need some help. I have to remove some content of Tolerance "column" (see attach). The string which I wish to remove is "+/- 0s" and replace it with an empty string. I need to remove this for each row where "+/- 0s" appears.
(4,431 Views)
Hi Samoth,
I dont know if I understood your requirement properly, but please check the attached snippet if it helps.
If this does not satisfy your requirement, then please give some more details.
(4,415 Views)
here you go...
Guru
Regards
Guru (CLA)
(4,413 Views)
Accepted by Samoth
I solved the problem. I saw your hints.
Thanks!
(4,395 Views)
How did you do that?
Regards
Guru (CLA)
(4,363 Views)
Hi Guru,
Actually I've changed some points of view. I misunderstood the idea that I must to remove only where the tolerance is not specified (zero) not entire column. I do that in another subVI.
Thanks, Teodor
(4,356 Views)
Then can you mark the post that helped you...
(4,345 Views)
