Remove zeroes
Hei, I tried to understand how the remove zeros posts work but it just isn't working for me so i cleaned up the vi.
Can someone show me how to remove them from the arrays in my vi?
Thanks alot!
Message 1 of 12
(5,640 Views)
That might make you look at the help file again
Message 2 of 12
(5,624 Views)
Hi Nunu,
good advice:
- go through LabVIEW basics as offered by NI on their website!
- learn to THINK DATAFLOW!
This is your VI after removing the most RubeGoldberg and using the AutoCleanup tool:
And this is how it should look like:
After learning to use shift registers you may simplify this snippet to use only one case structure…
@Jeff:
The OP apparently uses an older LabVIEW version without those fancy output tunnel options…
Message 3 of 12
(5,616 Views)
This snippet will remove 0's from an array.  You must have Labview 2012 or higher to use conditional tunnels.
Edit: remove the unnecessary NOT.
aputman
Message 4 of 12
(5,612 Views)
Hi nunu.
In your case structures, you are using the "Use default if unwired" in the False case. So, that means that when your number is not greater than zero, you are outputting the default value for the data types, which is zero. Hence, you are getting a lot of zeroes in your result.
Try to use the build in conditional terminal and wire in you boolean value from your "Greater than" function.
Note: You should always try to keep your dataflow from left to right. In your example VI, the dataflow is in every direction....
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
Message 5 of 12
(5,600 Views)
Hehe, 4 answers in short time Smiley Happy
This proves how helpfull this community really is!
Best Regards
Alex E. Munkhaus
System Engineer
Message 6 of 12
(5,594 Views)
@GerdW wrote:
@Jeff:
Missed the vi.property source version again!  (Of course the FP.Colors<> should have reminded me to check)  The back save + Ctrl+U looks like this:
and fully de-rubed to a LabVIEW 2010 style:
(Got to watch out for those boolen case structures)
Message 7 of 12
(5,588 Views)
Hi Jeff,
For me it was the missing connector pane in the FP window…
Message 8 of 12
(5,579 Views)
@GerdW wrote:
Hi Jeff,
Honestly, I never even looked at the FP
I usually drop uploaded vis on a blank vi BD (in case they run when opened) and Ctrl+double-click.  You miss those little clues that way.
Message 9 of 12
(5,570 Views)
Thank you very much guys, one of the given solutions did suit my case and everything works smoothly atm. Smiley Happy sadly,some of the given solution didn't work for me,coz the version of my program is outdated,but thanks anyway.
Message 10 of 12
(5,516 Views)
