Communicating with ITC510
I am new to using Labview so excuse any lack of understanding.
I am currently trying to control a Thorlabs ITC 510 Laser Diode Combi Controller (current and temperature). The output of this is controlling a laser which in turn is read from an optical spectrum analyzer (OSA). I have made up a vi which can take readings from the OSA when I just use the controller manually (the OSA works perfectly).
The problem I am having is that when I run Labview and try to use any of the libraries for the device, none of them work. When using the DAQ Assistant, it says that no supported devices found. When I use the NI Instrument I/O Assistant I can communicate with the device and the device has switched into remote mode. Also, the device is listed under connected instruments.
Oh, and I am using labview 8 by the way.
Any feedback on this would be greatly appreciated, thanks.
Message 1 of 12
(4,803 Views)
Exactly what do you mean by the driver does not work? You need to provide the error codes and messages that you get.
Message 2 of 12
(4,793 Views)
Thanks for the reply. I have attached a pic of the error when I use the get module stsus vi from the ITC510 library. Also I have attached a picture showing that labview sees that it is connected and one where I used the *IDN? command using the I/O Assistant. And as I said before the DAQ Assistant says there is not a supported device attached. Thanks.
Message 3 of 12
(4,776 Views)
Hi Pagz,
 Check this link http://www.ni.com/support/labview/visa/verr3.htm.
SrikrishnaNF
Srikrishna
Message 4 of 12
(4,770 Views)
The DAQ Assistant is not supposed to work since you do not have an NI DAQ device.
Message 5 of 12
(4,761 Views)
Hi Dennis,
Do you know the reason for the error I posted a screenshot of above? The link that was posted didn't work for me. Not really sure what to do....
Message 6 of 12
(4,753 Views)
I'm on my phone right now so I can't look up the message. Can you right click on the error code to get it or go to Help> Explain Error Code and then post the exact message.
Message 7 of 12
(4,747 Views)
Just did that there and it says that the error is undefined and that nobody has provided a description for the code...
Message 8 of 12
(4,741 Views)
Then please attach an image of the block diagram where the error code is being generated.
Message 9 of 12
(4,735 Views)
It's just one of the VI's that came with the driver download
Message 10 of 12
(4,728 Views)
