Rename VI in dll
When building a dll, I select "Rename this file in the build" for an exported vi and enter a different vi name.  I expected this would change the exported function name in the dll, but it doesn't.  Is it supposed to?
TIA,
Bill F
(2,625 Views)
Accepted by topic author bfarley
If you want to change the exported function name in the dll, you need to go to
Build Specifications->Shared Library (DLL)->Source Files->select file for export and then change it in "Define Prototype..."
Renaming the file in the build in "Source File Settings" does not affect the name of the exported function name. So this behavior is deliberate.
Marek S.
(2,574 Views)
