Usually ActiveX on a remote computer
I am trying to use JMP through ActiveX in my LabVIEW app in a exe format on all test stations.  However, the test stations do not have JMP.  JMP is only installed in one server computer.  Can all test stations call JMP on that server computer through ActiveX?  Would there an a comflict?  How do you do activeX on a remote computer?
Kudos and Accepted as Solution are welcome!
(2,722 Views)
Hi jyang,
I haven't tried anything like this before, one way I can think of doing it is to create a ActiveX VI to call JMP on your host computer, then stream the data to your remote computers. Alternately, you might be able to put the JMP executable in a shared folder and do Active X calls from the remote computers.
How much data will you need from JMP?
Jesse Dennis
Engineer
INTP
(2,650 Views)
