Repeat 2-D array N times & concatenate
I have a 2-D array that I would like to repeat N times and concatenate along the row dimension.   For example, repeat 3 times...
[ a a ]   =   [ a a ]
[ b b ]        [ b b ]
[ c c ]        [ c c ]
                 [ a a ]
                 [ b b ]
                 [ c c ]
                 [ a a ]
                 [ b b ]
                 [ c c ]
My current code almost works, but it complies the output in 3-D.   Any suggestions?
Thanks!
(4,150 Views)
Depends on how you did it. My guess is that you're either using the Build Array and don't have "Concatenate Inputs" checked for that function, or you're using a for-loop. There's a variety of ways to do this:
Message Edited by smercurio_fc on 06-16-2008 01:35 PM
(4,134 Views)
Thank-you for the examples.   I am using a for loop that is very similar to your second example.   I was just missing the reshape array steps.   I was getting correctly iterated 3-D output, but because of my newbie status thought I had screwed something up in the for loop.   I've implemented and tested the second example.   Works Great!   Thank-you!
(4,118 Views)
