Replace LF or CR or Both with WhiteSpace in LabVIEW
I am facing issue while replacing string. I have one buffer which may contains multiple CR or LF or both. I just want to replace these with the white space.
I am using "search and replace.vi" for this purpose, I have changed this VI to Regular expression by right+click. In input I have given my buffer, in search string input [\r\n]$ regular expression and in replace string I have given "Empty string" constant.
I think I have made correct changes for the issue but nothing working so far.
Pratik
(4,009 Views)
Accepted by pratik0403
Hi Praktik,
Simple solution without regex:
(3,967 Views)
Thanks for this simple solution..Smiley Happy
(3,936 Views)
But it still simpler with regex Smiley Wink
Ben64
(3,914 Views)
