Replace array sub-set for image manipulation not giving expected result.
Working with arrays in LabVIEW is relatively new to me and I'm having some difficulty with (what I'm sure is) a relatively simple function and would really appreciate some help.
I am trying to retrieve a column of pixels from an image and insert them into a larger image starting at a specific co-ordinate. I'm able to extract the array I need, but when I try to insert it using 'Replace Array Sub-set' into a blank array, I'm still getting blank values in the new array.
I've tried to break it down in it's own vi to actually understand what is happening with the arrays and I'm still not getting the result I'd hoped.
Visualisation of what I'm trying to do:
Block diagram:
Front Panel:
Actual application:
Using the IMAQ SetRowCol, I can make it work for the x-axis from the input map, but this puts the extracted column at the top of the image
I tried to change to the use of arrays and I have many failed attempts to get this to work under my belt, e.g:
The input map is a csv, with 3 values, the ID (x-pos in original image), New XPos, New YPos.
The attached 'Arrays Simplified.vi' is my VI I'm trying to understand the arrays with.
The attached 'Array Subset 3.vi' is my actual application, which has the Input Map and test image attached.
If I had any hair left, I'd be pulling it out, any guidance would be massively appreciated. I'm clearly making some kind of schoolboy error.
Aidan
(1,779 Views)
Accepted by Jee_with_a_J
Hi Aidan,
  1. You are not "inserting" into your source array, but replace array elements. That is a huge difference (in words and code behaviour)! Your "blank" source array is NOT empty/blank, but already contains several elements with value "0"!
  2. Works as intended.
  3. Does not work as intended (?): you try to replace elements of an empty ("Blank") array! You cannot replace a non-exisiting element…
Your item "3" shows you missed to use shift registers in that loop for the "Blank" array".
Again you missed to use a shift register to hold your array data! In each iteration of the loop you forget about all previous changes…
(1,762 Views)
Hi GerdW,
You have no idea how many of your solutions I have used over the past few years, feels like a privilege to finally have some direct input from you!
Okay, so I managed to fix my simplified arrays to make them work as expected - hoorah!
I've now spent the last 2 hours trying all manner of things to get my arrays to work with shift registers in my application but I'm not having any luck. It seems like it's iterating through correctly, but still getting a blank image.
I'd really appreciate it if you can point me in the right direction.
Thanks!
Aidan
(1,725 Views)
Hi Aidan,
I don't use IMAQ/Vision functions, so I can only guess:
  • it should be ok to get the image data from your IMAQ reference only once before the outer FOR loop and write the image data back only once after the loop.
  • it should be ok to create that image data array (blue 2D integer array) before the loop and only convert it to IMAQ image once after the loop, no need for IMAQ reference ("DstImg") before the loop…
(1,709 Views)
Why do you think you need a FOR loop to replace a rectangular subset with another rectangular subset from a different array?
All you need is ensure that you have a 2D subset (even if it is only one column wide!) and "replace array subset" can do it in one operation. Here is an exact and loop-free solution to the above problem:
Some general advice:
Please resize your array containers of the demo code to show a reasonable amount of elements and keep the upper left index at 0,0. If the array is too large, show the scrollbars. It is very difficult to see what going on if you have a 1x1 container and shif the index to a non-existing element.
(1,700 Views)
