Report Generation Toolkit hyperlink in a table
Having just purchased Report Generation Toolkit 1.1.2 for Microsoft Office for my LabVIEW 7.1, I'd now like to create an HTML report containing a large table.  I'd like to fill the cells of the table with Hypertext links to various documents.  I can't see any vi's in the toolkit that do this  Can someone please suggest where I should be looking, or the best approach to this problem?
(3,707 Views)
Accepted by JohnBoy
Hi JohnBoy,
connect as your table data a string with all tags you need for a link. In your case <a href="your document">your link name</a>.
Hope it helps.
Mike
(3,690 Views)
Hi JohnBoy,
Please see the following KnowledgeBase Article: Creating Hyperlinks to Files on the Local Hard Drive.
Claire Reid
(3,662 Views)
Also, there is a VI called Append Hypertext Link Anchor to Report . This might help you.
Claire Reid
(3,661 Views)
