Report Generation
Hi I get a error if I add the Report Classes and create an exe.
That's the error:
Fehler 1003 ist bei VI-Referenz öffnen in VISL_getDSCSharedDir.vi->VISL_detectAndCopyVISvr.vi->AB_Engine_Copy_CustomIOServer_Files.vi->AB_EXE.lvclass:Preview_Build.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller aufgetreten
What's the problem?
Message 1 of 9
(3,969 Views)
What version of LV are you using?
Are you sure that the application is executable in the development environment?
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(3,964 Views)
I'm working with LabView 2010.
The application is running without problems. It seems, that vi.lib\lvdsc\common\path\PTH_SharedDir.vi is responsible. If I try to execute PTH_SharedDir.vi I get an error because a dll is missing. dsccommn.dll which I cannot find on my hdd nor in the internet.
Message 3 of 9
(3,958 Views)
Is a build of an exe successfull if you dont use the Report Generation toolkit in the application?
Norbert
Norbert
Expert: Geometry
Message 4 of 9
(3,954 Views)
No, the dll is missing again. Where can I get the dscCommn.dll?
Message 5 of 9
(3,949 Views)
Accepted by stagediver
This dll should be in C:\Program Files\National Instruments\Shared\System manager\11.0\vi.lob\lvdsc\common
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 6 of 9
(3,947 Views)
Are you using shared variables?
LV DSC is the source of this folder (including the DLL). I don't know why you are requiring this for building the EXE except you are using DSC features, most likely because of settings for shared variables....
Norbert
Norbert
Expert: Geometry
Message 7 of 9
(3,945 Views)
Thanks Thoric,
I just copied the dll to the path, where the builder was searched for it and now it works 🙂
Message 8 of 9
(3,921 Views)
There could still be other issues lurking, as Norbert mentioned this dll is a part of LabVIEW DSC. It might be worth checking your installation.
Message 9 of 9
(3,918 Views)
