â04-19-2022 07:10 AM
Hello community!
My problem today is with using the report generation toolkit, that I want for keep my data during the run of my testing. In an isolated vi it could work without problem, but when it is being part of the project to control with Compact RIO all vi's get broken/ dependencies problem.
Saw the LabVIEW Report Generation Toolkit VIs Broken - NI, but my current LabVIEW version (2020) doesn't have the "relink invoke node" and doing it manually is just not working either (I reconnect and nothing changes).
My question is for is there another way to solve this or a new version of the vi's corrected? or in case that no, another saving of the data that you can recommend me? (I tried with "write to measuring file" but that makes the vi to immediately stop when trying to run.
Thank you in advance!
â04-19-2022 07:13 AM
do you use Labview x64 bit version?
â04-19-2022 07:20 AM
Hi AeroSoul!
No, I have the 32 bit (the 64 was having some incompatibility issues with CompactRIO...)
â04-19-2022 08:26 AM
Are you using the RGT on the RIO ?
The Report Generatin Toolkit do not work on a RIO, there are too much Windows function needed for it to run on a RIO.
