Report generator
Can i generate excel file(.xls) without using Report Generator toolkit??
(3,642 Views)
Yes but you need to develop your own code by invoking Excel (using Activex)
(3,628 Views)
How? i mean, do you have any reference or tutorial how to manipulate activeX. please
(3,625 Views)
ExcelWriteDatatoExistingFile.pngAttached Snippet shows how to write data to an existing Excel File, Explore more in the Methods and properties of excel to add more features into it.
(3,606 Views)
There are several third-party toolkits out there like XLR8 that let you work with excel files that do not require an installation of Excel on your computer.
Regards, Jens
Kudos are welcome...
(3,590 Views)
http://www.ni.com/newsletter/51339/
(3,585 Views)
ActiveX is technology developed, and now largely abandoned, by Microsoft.  You can still find vestiges of it in some Windows products, but development has largely ceased.
There are always "trade-offs" -- you can purchase LabVIEW's Report Generation Toolkit or a LabVIEW edition that contains it, purchase a third-party application that can interface with Excel, give up using "native" Excel and use a Comma-Separated-Variable (Excel-like) format that LabVIEW easily supports, hire a Developer skilled in ActiveX to help you, or spend the time to learn this technology yourself.
(3,568 Views)
