Report without MS Office
I need to establish an extensive report in Lab View but should not use MS Office. With standard report vi's it seems to be very hard to create such a report (contains text, tables and a lot of lists).
Is there an easy way to generate an extensice report without MS Office?
Thanky you very much.
(3,046 Views)
What version of LabVIEW are you using? Have you got the report generation toolkit? Could you explain a bit more as to what your report is handling? So people here can understand your needs and maybe able to suggest a solution.
(3,037 Views)
you can make a html report, browsers are free.
paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,022 Views)
