Sychronizing a DAQmx device to the PC's system clock whilst continuously sampling
Whilst running continuous sampling tests on a simulated DAQmx device I noticed that the timestamps on my data were diverging rapidly away from the system time on my PC. Is there a way of synchronizing the device with my system clock after a task has been started (whilst still using continuous sampling)?
To overcome the problem I've looked into trying to find out the current time on the DAQmx device in order to apply a fiddle factor to my data and re-sync it back up to the PC's system time. Unfortunately the only way I have found to do this is to count the number of sample clock pulses from the hardware and calculate its current time from that. Can anyone think of any better ideas? I cannot read the timestamp on the data points because these are buffered and their times will be out of date.
To count the number of sample clock pulses from the DAQmx device, I have created the VI in the attached picture. However, despite not producing any errors it also does not produce any ticks to the timed loop. Have I made any mistakes in my design? The task in the VI is the one I am using to acquire my data points.
Any help would be much appreciated, kind regards,
Tim
Message Edited by Tim_Itdev on 01-08-2008 06:17 PM
Message 1 of 1
(2,600 Views)
