Reproduce repeated .csv file waveform
I'm not-advanced user of LabVIEW and I'm having trouble trying to code something, which in principle is very simple. Smiley Wink
I have captured a periodic waveform (from the "real world") in a ".csv" file. What I would like is to be able to
  1. read it continuously and having it repeat itself after the data points has finished. Eg. I have collected only one period of a sine wave in my ".csv" and I want to have a never-ending sine wave from this data;
  2. be able to change the sample read frequency in real-time. By changing the sample read frequency, slow down or fasten up the replicating of my signal. This includes not only by the end of the data collected by also during the replication of my data - mid-file. Eg. Frequency modulate a signal with my sine wave period.
I was trying to use a read from spreadsheet block and then build a waveform or vector, to which an adjustable frequency reads the data points. Is this possible?
Thank you very much!!
(3,924 Views)
Please attach your code (the actual VIs).  This tells us a lot of things, including what you have tried, provides some idea of your LabVIEW knowledge, shows us where you might have misconceptions, tells us the Version of LabVIEW you are using, etc.  And, not to be too cynical, demonstrates that this isn't a "Please do my homework for me" request.
(3,896 Views)
Accepted by vglinden
Hi Bob,
After working for quite a while I was able to sythesizer what I needed by copying the .csv contents to a string and reading it with a "from spreedsheet" function.
Thank you
(3,870 Views)
Good for you.  Since you didn't attach any code, I still don't know much about you or your LabVIEW environment (such as which Version of LabVIEW you are using -- the function names changed a few years ago).  Your way works, but there is also a "one-step" function that would have been simpler and "more logical" to use.
(3,862 Views)
