Request VI for simple operator user interface on Teststand with yield information
I am searching for example labview VI with simple operator user interface on teststand with yield information.
I get to find your example as below link
http://zone.ni.com/devzone/cda/epd/p/id/3608
However, the example VI is too old which is labview version 5.1. I am using labview 8.5 and cannot view and access this example.
Can you please convert and provide the example VI to me to access in version labview 8.5 ?
(2,996 Views)
Try this, now updated to LabVIEW 8.5.    It was a pain to find all the files, because it assumes you have TestStand 2.0 as the active version.
PH
(2,983 Views)
I tried to use your simple operator user interface on LV8.5 on my PC but got a lot of broken link due to my teststand version is 4.0
Please help provide the simple operator userinterface on LV8.5 but can use with teststand version 4.0
(2,943 Views)
So, Teds, what's your going rate for contract work? Smiley Wink
(2,934 Views)
chan
That is not an easy task.  The Operator Interfaces' changed extensively from TestStand 2.0 to TestStand 4.0.  The latest Operator Interfaces use the UIControls that were not introduced until TS 3.0.
Perhaps the eaisest task would be to just extract the code that does the 'yield' calculations and implement that into the latest Operator Interfaces that ship with TestStand.
PH
(2,915 Views)
