Why does this .vi round my numbers?
I am using a high accuracy DVM with 6 and 1/2 digits of precision for a reason, because I need the accuracy, so why is this .vi rounding off my numbers to 3 decimal points?
(2,527 Views)
Accepted by topic author LarsUlrich
Write to Spreadsheet defaults to 3 places.  Right click the Format terminal and create a constant.  Change the 3 to desired # of decimal places.
(2,513 Views)
Turn on context help and hover over that function.
You will see there is an input at the top called format, and its default value is %.3f.
You need to wire in another format such as %.6f.
(2,509 Views)
