Request link for Labview 2011 SP1
I request the link in order to download the Labview 2011 SP1.
I have one of the bug that SP1 fixes (front panel corrupted, cannot open vi any more, see discussion http://forums.ni.com/t5/LabVIEW/LabVIEW-load-error-code-3-Could-not-load-front-panel/td-p/1895379/pa...), but the link for downloading it has disappeared.
Please, if someone knows tell me the link for downloading it (32 bit).
Message 1 of 13
(5,249 Views)
All of the recent major LabVIEW releases can be downloaded from here: http://search.ni.com/nisearch/app/main/p/ap/tech/lang/en/pg/1/sn/n8:28,ssnav:pdl/
And here is a link to the f2 patch: http://joule.ni.com/nidu/cds/view/p/id/3312/lang/en
Message 2 of 13
(5,244 Views)
No 2011 SP1 in the link you gave to me. Actually that was the reason why I opende this topic.
Could someone say to me the link please?
What should I do?
Message 3 of 13
(5,241 Views)
What should I do?
Yes there is
Message 5 of 13
(5,229 Views)
I cant't see it in the link you gave to me. Probably in my country is not allowed to download it.
Message 6 of 13
(5,222 Views)
What do you see when you visit that link?
Message 7 of 13
(5,220 Views)
No results found for 2011 SP1
Message 8 of 13
(5,218 Views)
Accepted by topic author gnappo
I found it here
http://download.ni.com/support/softlib/labview/labview_development_system/2011%20SP1/
Anyway, there are some problems with the link you gave to me. I thank you all the same because what happens is somethink wronk with the national instruments site which is not the same for all the countries (web designers should check and correct the bug).
Message 9 of 13
(5,213 Views)
Which is the correct procedure to upgrade to LV 2011 SP1? Should I completely uninstall LV 2011 or not?
And what about NI-DAQmx and VISA? Have I to uninstall and reinstall or the upgrade is not affecting the drivers?
Message 10 of 13
(5,192 Views)
