Error occured while building project
Build error occured while compiling the project in labview11. It asked to contact ni whith following refrance.
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_PreBuild.vi >> CDK_Validate_DistParts_2010.vi >> CDK_DistParts_GetInstalledProducts.vi >> CDK_Utility_EnableLogging.vi >> NI_MDF.lvlib:MDFCommon_EnableDebugLog.vi
I need to build an installer for my project. I am doing for first time in Labview11. Previously I use to do without any errors in LBVIEW 7.1
Pl help me.
Regards
Prasanna
(3,320 Views)
I am having this same error. have you gotten any answers yet?
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,194 Views)
Have you tried to check these settings:
Not sure if it helps in your case(s), though.
The application builder is an esoteric exercise in black art, best wielded only by the chosen ones. Smiley LOL
Br,
/Roger
(3,191 Views)
Ii did, yes. I figured my problem out though. It was a dll that wasn't loaded correctly.
(3,184 Views)
