Requirement Gateway Tag
For NI requirement gateway, if a subvi fulfill multiple requirements, what would the syntax be?  I understand that I can put
[Covers: ReqID1] in the VI documentation of subvi 1 if it satisfies ReqID1.  What if the subvi would satisfy both ReqID1 and ReqID2?  Is [Covers: ReqID1, ReqID2] the correct syntax?
Kudos and Accepted as Solution are welcome!
(2,825 Views)
Accepted by jyang72211
jyang72211 -
The correct syntax would be:
[Covers: ReqID1][Covers: ReqID2]
or
[Covers: ReqID1]
[Covers: ReqID2]
Hope this helps.
Manooch H.
(2,818 Views)
