Requirements Gateway 1.1 can't detect pictures in a word document
Dear Developers,
The following problem occured, while I was using Requirements Gateway 1.1 (Build 586) -> I inserted pictures in several formats into an exmple word file, but there was no sign of them in any of the views.The default "Word" type was used.
Do you have any idea, how could I utilize pictures in a word file?
K. L.
(2,604 Views)
Accepted by KnabLaszlo
K.L. -
You have to enable the With Images variable for the document when configuring the project. When this is enabled, the images are displayed in a popup window when you select the requirement in the Management View.
Hope this helps.
Manooch H.
(2,595 Views)
That checkbox solved the problem.
Thank you.
Knáb László
(2,579 Views)
