Reset I2C connection within LabVIEW
No, the VI continues without error.
Only the measurement values return to zero.
Message 11 of 15
(961 Views)
Hi Ruud,
I took a look at your project. Looking at the I2C_Host.vi I saw some disconnected wires regarding the I2C Communication, this could be the cause of your problems.
Frank
Message 12 of 15
(946 Views)
Hi Frank,
The file "I2C_Host.vi" is not used in the current project. I should have deleted that before uploading.
Unfortunately, I still did not solve the problem.
In short: In case the pressure sensors hang-up, I can only restart the test set-up by deconnect/ re-connect the power supply.
Restarting the Project, VI or eRIO 9148 does not have any effect. Somehow I would like to "simulate" this re-connecting the power supply within LabVIEW.
Thanks a lot for your help,
Ruud
Message 13 of 15
(915 Views)
Hi Ruud,
unfortunately there is no way to simulate a power down. What you could do, is  connect a via network switchable power supply to your test-setup and program some logic to switch that.
Frank
Message 14 of 15
(904 Views)
Hi everyone,
this is my first post... I write because I have to use NI 9402 as i2c master to communicate with NXP PCA 9698 but I am not sure if this is possible with NI9402.
If no, is there any NI ethernet device that I can use?
Thank you in advance,
Message 15 of 15
(832 Views)
