Reset XY Graph on Button Press Fully
Accepted by topic author Julsbng
@Julsbng wrote:
I got it the way you did it and its working thank you. I still got the same problem sadly.
Do i now have to reinitalize to default?
Best regards
Notice the coercion dot? Your constant to initialize the array needs to be complex! (right-click...representation...cdb).
The current code resets before another point is added. You can also reset after the build array, but it won't really make a difference after the next iteration.
As I said, all that matters is the data in the wire. If the array is empty, nothing will be graphed. No need for properties and methods.
Message 11 of 24
(1,016 Views)
Okay, thanks. If i want to save my data now it just saves the Angle values and not the Torque values.
How can i fix that, do i have to save the torque seperatly in an array?
Message 12 of 24
(1,013 Views)
you can use complex to re/im to get the x and y values to save.
I would NOT do it after the loop, but as a state. Currently, all data is lost if you would accidentally abort the VI.
Message 13 of 24
(1,010 Views)
So i need to reset the values which comes from the wires of the measurement right?
I need to reset my counter then to 0, thats the problem i understand... How can i do this?
Message 14 of 24
(1,007 Views)
The "select" replaces the data in the complex 1D array with an empty complex array. That's all you need to do.
Message 15 of 24
(1,004 Views)
I did, but the value of the Angle Measurement is still in the wire... I need to reset the angular position (the counter TTL) to get the value 0 in the wire and not the last one which was measured.
   Now its resetting the graph but the value of the measuremnt is still the same
Message 16 of 24
(1,000 Views)
Thank you, i will do this.
I will do it inside the loop with a button to save. Thank you very much
EDIT: This worked perfectly thank you very much
Message 17 of 24
(993 Views)
I don't see anything labeled "counter". Please explain.
Message 18 of 24
(983 Views)
The angular Position is a counter.
  So i need to reset this counter otherwise there will always ne the last value of the measurement. This counter only resets when i stop and run again.
Message 19 of 24
(978 Views)
I don't have any drivers install and thus cannot look at your express configurations.
A counter outputs a relative value, so all you might need is keep the reference value in a shift register (or feedback node) and subtract it from the measurement. When you reset, place the current value in that shift register.
Message 20 of 24
(968 Views)
