Reset.
Right now im having a program that will count down 12 hours. But the Elapse Timer function doesnt have the kind of function that i need. Whenever motion sensor senses a motion it should reset back to 0:00 but i cant seems to do it because of the limitation of the elapse timer function. My timer has to count 12 hours so i cannot change the time target so that it can use the AUTO RESET mode. Please help!!! Thank you very much!!
Bobfun.
Message 1 of 8
(5,133 Views)
LabVIEW is a programming language - you can make your own timer VI using the 'get date/time in seconds' and an unitialised shift register (to store the start time).
(blog)
Message 2 of 8
(5,116 Views)
Hi bobfun,
you have been told to stick with your original thread. Why do you create the next thread for the same topic?
I think it has the functions you need…
Message 3 of 8
(5,114 Views)
Hi GerdW,
Hi, as it has solved my problem from the previous thread i am starting a new thread for a new topic. Yes it has a counter timer, what u didnt get is that, When the motion sensor sense a motion the timer should be reset back to 0:00 but it doesnt have the function, as it has only time target and i need it to set 12 hours, so auto reset mode doesnt work. Right now im attaching the VI so that u can better understand what i meant.
Best Regards,
bobfun
Message 4 of 8
(5,093 Views)
Hi GerdW,
Best Regards,
bobfun
Message 5 of 8
(5,092 Views)
Hi bobfun,
well, when I read the help for ElapsedTime it clearly mentions a "Reset" input…
What else do you need?
Message 6 of 8
(5,081 Views)
Hi GerdW,
I have managed to solve the problem on myself with the VI attached. Right now how can i setup a RESET button so that it will go back to the Time target? sorry and thank you!
bobfun
Message 7 of 8
(5,049 Views)
Hi bobfun,
please attach your VI in LV2011. Right now I don't have LV2013+ available…
Message 8 of 8
(5,045 Views)
