Resetting a front panel button
I'm using a record button on the front panel, in "switch when pressed" mode. I run the VI, then press the record button. After stopping the VI, the button stays on. How do I make the button automatically return to the OFF state when running the VI the next time?
(2,712 Views)
Accepted by tmeTech
Set the property node value to "False" it will get reset.
(2,711 Views)
