Resize Array in front Panel LABVEIW NXG
Hello everyone
how can i change the array size in front panel i don't mean the number of rows or columns but the size of displaying this array
i am making my project on 1920x1080 display but this array is big on 1280x720
i can change this in normal Labview but now how ? for controls a button or so on .. i can but for array i couldn't..
please help .. thanks
(2,774 Views)
I assume this is related to this discussion.
An array is just a container for controls/indicators, so if you make your colorbox smaller, the array will be smaller while displaying the same number of elements.
Stll for a 1280x720 array on a 1920x1080 display, the elements need to be smaller than two pixels unless you use scrollbars.
Maybe you should use an intensity graph instead.
(2,738 Views)
