Resizing Front Panel Objects
Anybody,
Is it possible to resize a group of selected objects to the same size?
Thanks.
Petter Kristiansen
(3,847 Views)
Unfortunately, this isn't something that the LV editor makes very easy,
not yet. There should be a yellow tip strip that appears each time you
move or grow an object. When growing, it will give the width and
height. With a little practice, you can resize other objects to match.
As I said, not that easy.
Greg McKaskle
(3,847 Views)
I found another way too.
I created attribute nodes for the objects and programmatically adjusted
their sizes, then I
removed the attribute nodes when I was satisfied with their sizes. Not easy
this method either, so I hope a editor function for this will be implemented
soon.
Thanks a lot
Petter Kristiansen.
Greg McKaskle wrote in message <376AEC63.72AE224@austin.rr.com>...
>As I said, not that
easy.
>Greg McKaskle
(3,846 Views)
I recently attended a National Instruments seminar here in Vancouver, Canada
where they took some time to introduce LabView 5.1. When they told us that
it automatically resizes all windows and objects, the room burst forth with
applause! I guess this improvement has been a long time coming.
Petter Kristiansen wrote in message
news:_R5a3.256$vt6.1151@news1.online.no...
> Anybody,
> Thanks.
> Petter Kristiansen
(3,848 Views)
Hi
i'm sure resizing selected objects to same width and height in LV7.1 is possible,by using Front panel - resize objects >>set width and height option,but in early version but whether this option is available or not ,i dunno and our LV seniors may clarify it.
(3,694 Views)
