Second serial port for CompactRIO
Is it possible to use two serial ports with a CompactRIO? Until now I use just the built in port, but I would like to use a second one. I couldn't find a module with another serial port. Is it possible to simulate a serial port by software with for example the cRIO-9401 in combination with a line transciever?
Thanks for any help
David
(3,011 Views)
If you don't need the hardware flow control and your com port has some idle time you can think about some hardware to switch the port Smiley Wink
Years ago I have seen ready to buy RS232 1 to 8 port switch that could be controlled by serial commands ...
Or you use a Ethernet2RS232 converter and have as many ports you like Smiley Very Happy
Greetings from Germany
Henrik
LV since v3.1
(2,998 Views)
