Resource Not Found: NI_AAL_SigProc.lvlib
On a computer I upgraded from LV2013 to LV2016.
My program loads and runs correctly when built with LV2013.
When trying to run the exe that was built using LV2016 I get a Resource not found error.  It could not load Peak Detector.vi from the NI_AAL_SigProc.lvlib library.
I checked my Device Driver install.  Would someone please tell me how to fix this error?
(4,439 Views)
Do you have Full LabVIEW 2016 or Base? It is not included into Base version
(4,428 Views)
Nah, if you can build exe, you can open vi.
Do you run it directly after build, on the same PC?
Try to copy your main build specification, and set as source vi one that includes only peak detector.
Do you build into same destination as 2013? Try to change.
Try to force recompile starting from main vi (Ctrl+Shift+Click on arrow)
(4,426 Views)
I have Professional Development System.
I'll try your suggestions.
(4,417 Views)
Still no solution yet.
Things I have tried:
  1. Run the exe right after the build on the same PC.  Same error.
  2. Put the Peak Detector subVI in a VI and compiled that VI.  Works.
  3. Compiled one of my medium level subVIs that has a call chain that called the Peak Detector subVI.  Works.
  4. Used different PC.  Same error.
  5. Compiled under LV2015.  Same error.
  6. Mass Compile.  Same error.  This one really confuses me.
  7. Peak Detector.vi is called from two places in my code. One is from a VI in an lvlib.  So I Mass Compiled the lvlib.  And also made all the VIs public.  Same error.
(4,381 Views)
Thinking about this further I am wondering if there is some conflicting code in a Disable Structure.
Is there a way to use scripting to look for Disable Structures that have peak Detector.vi in them?
(4,374 Views)
Accepted by Mark_L
Solution Found.
lvanlys.dll was down level.  This was because the directory location I needed to place the exe used a different lvanlys.dll than the latest from the build directory.
Copied lvanlys.dll to location where the exe would use it.  Now the exe runs.
(4,368 Views)
