Responsiveness decreased when library added to project
I have an labview library that contains VIs, controls,... When I open VIs directly from the library everything works normal. But when I add the library to an project and open VIs, labview responsiveness is decreased (switching between front panel and block diagram takes 2 sec, moving stuff on block diagram is not smooth,...).
Any idea what might cause such behavior?
Andrej
(2,500 Views)
obviously, the problem originates from a packed library. I put the packed library in user.vi folder and created new palette. If I replace that packed library with LLB that contains the same VIs, everything works smooth and normal.
Andrej
(2,477 Views)
Hello Andrej,
It's difficult to recognize the source of the problem not seeing your code. Is it maybe possible for you to share it or at least share that VI, that you think causes problems?
BR, Peter
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
(2,455 Views)
