webservice
Dear All ,
I am using Labview 2010, Full developmet, to bulild application  control using Webservice. But when i try to use examples from  post , i can build  and deploy it but unable to access it through my web browser. The same examples works for labview 8.6.
Is there any solution for this?  .
Thanks alot.
(3,156 Views)
Dear Bstart,
It is possible to review the active webservices on your PC using the distributed system manager. Therefore you need to change the webservice .ini file in order to make it visible in the distributed system manager, please follow the following KB to arrange this.
After this open the example project, deploy the webservice again and see if the specific webservice is available in the distributed system manager under webservices (can be fount under tools).
Martijn S
NI Netherlands
(3,143 Views)
Dear ninlmartijn,
I tried it  with all settings but still my webservice is crashing when i deploy .
pls I need ur help.
(3,129 Views)
Dear bstar21,
are webservices visible in the distibuted system manager? Please notice that there is a item 'webservices' and under this there will be the specific webservice you are trying to deploy see attachment). This will give us a direction where to look.
Is the webser running under services (NI application webserver), can you restart it (please review through the windows configuration; see second attachment). Can you try with your firewall temporary switched off?
With deploying is there any error information?
Martijn S
NI Netherlands
(3,103 Views)
