Restrict LabVIEW deployment on NI sbRIO
Hello everyone,
I've searched a lot to find a solution, but couldn't find any.
I need to protect my NI sbRIO controller from deploying any application from LV.
For example, if anyone with LV connects to controller's network, he should not be able to deploy anything to sbRIO before filling controller's credentials.
From controller's web config I've removed all permissions from 'everyone' group, and set password for 'admin' user.
After that, the NI MAX requires password before saving anything to controller, but LV project doesn't require anything before connecting to controller and deploying a VI on it.
Could you please help me?
Thank you in advance.
Khoren
(3,377 Views)
Accepted by topic author khoren.j
Which Single-Board RIO device are you using (Linux or VxWorks RTOS based?)
The following whitepaper discusses how to protect a Single-Board RIO or CompactRIO from unauthorized access.
Overview of Best Practices for Security on RIO Systems
https://www.ni.com/en/support/security/overview-of-best-practices-for-security-on-rio-systems.html
It sounds like you need to configure the VI Server Access in the Part 1 of the security whitepaper.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(3,350 Views)
