I have an application that accepts a 24 bit number and does some simple mathematical operations (see attached). If number 3(a probe) receives a number lower than the constant that is being subtracted from it, which should result in a negative number, number 6(probe) displays a much larger, positive integer.
I'm sure that I must be missing something simple somewhere.
I thank you for your help in advance.
Ron Deavers, CLD
