Retrieve appropriate 'Documents and settings' (or home) folder
tst wrote:
To get to the APPDATA directory, you should use the recommended Windows way of calling SHGetFolderData instead of building and stripping, as this will work in different languages, versions, etc.
Hi tst,
      It seems (in Raistlin's original post) that code portability across operating systems (Windows/Linux) might be desireable.  By using the DefaultDataDirectory program-constant he can achieve this.
Cheers.
Message Edited by tbd on 03-23-2007 05:24 PM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 11 of 17
(1,555 Views)
Or you can create a different VI for each OS and call them dynamically using the conditional disable structure or the Application.OS property. More complex, but also more "correct".
___________________
Try to take over the world!
Message 12 of 17
(1,527 Views)
Hi tst,
... just because you can, doesn't mean you should - and your assertion (re: 'more "correct"') seems rather ambitious. Smiley Wink
If not this, then, under what situation would it be "correct" to exploit the cross-platform implementation of the DDD-constant?
To my mind, "complexity"  is one of many factors that determine "correct"ness, and the solution you suggest seems as "elegant" and "appropriate" as using a bull-dozer to sweep the floor - when a broom is within arms-reach!
Message Edited by tbd on 03-24-2007 06:44 PM
Message Edited by tbd on 03-24-2007 06:45 PM
Message Edited by tbd on 03-24-2007 06:46 PM
Message 13 of 17
(1,521 Views)
Sorry tst, "bull-dozer" comparison was not fair Smiley Happy
 (and "arms-reach" should have been "arm's-reach"):smileywink:
Message 14 of 17
(1,508 Views)
Generally, I would agree with you. Using a single property is much better than having to write a seperate VI for each platform and call it dynamically, etc. but in this case you should note that the intent was to get the DDD and then strip and build to get to the APPDATA folder, and that's bad form because the APPDATA folder could change places. Obviously, you can use the DDD itself for storing the data, but I don't like NI's decision of putting it inside My Documents instead of inside Application Data.
It's possible that I'm just more affected by other stuff I know. Try reading Raymond Chen's blog. He's a programmer from Microsoft who often talks about why certain things are the way they are in Windows and how MS does all kinds of tricks to fix the mistakes other people make so that the programs continue working nicely. It makes for an interesting read.
___________________
Message 15 of 17
(1,502 Views)
I do agree with the idea of avoiding work-arounds, and it's a pity LabVIEW does not point to the APPDAT folder. Especially if you take into consideration changes like for example Windows Vista. Maybe it's better to do things the right way immediately instead of trying a temporary work-around.
Message Edited by Raistlin on 03-25-2007 05:42 AM
Message 16 of 17
(1,500 Views)
By the way, it's "SHGetFolderPath" and here is an example implementation:  http://forums.lavag.org/System-Variables-in-Windows-t2785.html&pid=13084&mode=threaded#entry13084
I think I remember seeing an implementation on the LAVA forums.
Message Edited by travispape on 09-28-2007 11:56 AM
Message 17 of 17
(1,327 Views)
