Return to run the program again
Hello all!
I'm wondering if it is possible to return to the last step of the program to run it again in labview.
For example, a vi doing computation, if the final result doesn't satisfy a certain standard, I would like that a one button diagram shows out saying "the
program should run again", and when I click the "OK" the program automaticly re-run.
Please let me know how could I realize this. Thanks in advance!
Chao
(3,407 Views)
Sounds like a state machine.  Possibly with an event structure that looks for a button press.  When you press the button the event is generated and then the state machine goes into the state that does the work you want.  LabVIEW comes with several examples of state machines and there are a few white papers.
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
(3,374 Views)
Accepted by jcraffael
Hi Chao,
that sounds even more simple than a StateMachine: all you need is to put a while loop around your VI with a button "Continue" (or "Stop") connected with the loop conditional terminal…
(3,366 Views)
Hi Gerd,
That works! Thank you very much!
Chao
(3,357 Views)
