Reverse String
Is there any other simpler way to reverse string (without using 'Reverse String' function) using labVIEW besides the one that I tried in this VI attached below?
Thanx.
Message 1 of 8
(9,402 Views)
Not viewing your code...
Method 1(Using Loop)
Use array subset and extract single element at a time in a loop ...
The element should be from last to first..
Then use shift register and concatenate string to concatenate single character into string values...
Method 2(without loop)
Typecast string into an array of integers(ASCII Values)
Reverse the integer array created.
Again Typecast integer array into string...
Message 2 of 8
(9,389 Views)
Message 3 of 8
(9,367 Views)
The 2nd method you suggested was exactly like what I tried. I'll try the 1st method. Just a question, how to read the element should be from last to first?
Message 4 of 8
(9,354 Views)
Accepted by MrsBlackSuit
Use string subset in a Loop with Length of String subset is 1 and decrement the offset from String Max Length to Zero.
Message 5 of 8
(9,348 Views)
Thanx.
Why would you want to do anything other than the most effecient way, except to learn about something else?  (Is this homework, in other words.)
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(9,313 Views)
Once you have a Byte Array, reverse that array and turn it back into a String.  Three functions between input and output string -- hard to beat that!
Oops -- I didn't see that this answer was already given ...
Message 7 of 8
(9,282 Views)
Here's a "Rube Goldberg" soultion... If that's what you are looking for 😛
=== Engineer Ambiguously ===
Message 8 of 8
(9,274 Views)
