Reversing the FFT outcomes
Hi from Sth.Korea. I've currently started using Labview to make ANC system.
As a beginner, I've made quite simple FFT circuit and ran into a problem.
1st, I wanted to create FFT output of the sin wave and create FFt.
2nd, after the FFT, I've tried to reverse the FFT output.
The problem is, when I made reverse form of the FFT, the outcome was quite
different with what I've used as input. The amplitude became really small and I can't figure out why...
Please help me you awesome people around the world~
(3,697 Views)
There are a variety of ways to scale Fourier coefficients. One way is to arrange the forward and reverse formulations to be the same except for the interchange of Time and Frequency domains -- when you do this, you need to normalize both sums by dividing by 1/sqrt(N).  Another (common) way is to ignore N for the forward transform, and divide by N for the Inverse -- if you read the LabVIEW Help for the Inverse FFT, you'll see this is the convention used by LabVIEW.  The numbers you get out are 1/N as big as you "expect" -- you can fix this by rescaling your plot's Y Axis by N (or multiplying your IFFT values by N).
Bob "It's all in the Math" Schor
(3,677 Views)
First, I changed and cleaned up your block diagram a little.
Second, you were close. The output of the FFT should feed directly into the InvFFT. No normalization is needed there.
The only place you need to normalize the amplitude (by 2/N) is before you plot the FFT results. The units for the FFT are are N/2*Vpk (for freq > 0). Multiplying N/2*Vpk by 2/N leaves you with Vpk. Note: the DC unit is handled slightly different.
from NI example - FFT and Power Spectrum Units.vi
(3,643 Views)
I'm so sorry for being late to say thank you. Your answer was a literally tremendous help to me. Once again, Thank you!!!
(3,584 Views)
Good evening! I have questions regarding the usage of Active Noise Cancelling(ANC).
I'm trying to create a simple active noise cancellation system using Labview adaptive filter algorithm to cancel few sine wave noise.
The thing is that, should I use FPGA when cancelling just sine wave?
By the way, I use labview 2018 and already have COMPACT RIO.
Hoping for your answers.
(3,586 Views)
If you use LabVIEW on windows only, It may occur two problems.
1. Phase shift
2. Limit of frequency shift
Even if you're using a nice instrument device, the feedback algorithm should be run on the software.
Using FPGA is a better solution.
(3,557 Views)
