Right axis ticks and negative numbers
Has anyone else noticed that when you have a Y axis on the right side of a graph and have ticks showing, it can be confusing in that positive numbers look like negative numbers?  I've played a little bit with custom formatting of the numbers, like adding spaces before the number.  Any other known improvements?
   DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
(2,671 Views)
Accepted by topic author Dave_Thomson
You could change the color of the labels. That might make it a little more clear that it is not negative.
Tim
GHSP
(2,628 Views)
Thanks.  That's pretty much what I ended up doing.  There are two traces, different colors, one on each (left and right) axis.  So I made the axis labels colored to match the trace colors.  Helps the user see what trace is on which axis, and makes the ticks (still black) not look like negative signs.
Maybe I should put in a suggestion for ticks that go inside the axis...
DaveT
(2,621 Views)
