Right-click on a VI with missing dependencies hangs LabVIEW
Here's the flow:
1)  Download a VI from the forums that has a missing dependency
2)  Add the VI to a project
3)  Right-click on the VI to see if it's set to run-on-open
4)  Wait a very long time for the dependency load to fail
How do you all handle the forum VIs? Is it as simple as checking the Files view for missing deps - and only RMB if none are missing?
I can't find any of the "silently ignore all" posts/ideas except for opening refs.
When I create new VIs and force a dependency failure, there is not a long delay.
(3,055 Views)
I tend to just open the VIs directly.  If there is a dependency missing, there is a dialog that shows LabVIEW trying to find/load the missing VI and there are three buttons to Ignore, Ignore All, and Cancel.  The Ignore All is what the Idea Exchange item became.
(3,047 Views)
I'm being paranoid about opening VIs directly on a work PC when they might be set to run when opened. Think Lithium has a plugin to check for harmful VIs? 🙂
(3,045 Views)
How do you tell if the VI is set to Run When Opened?  If you are opening the properties dialog, the VI still has to load.
***Just performed an experiment***
Opening the VI from the project overrides the Run When Opened.  Good thing to know.
But still, when you try to open a VI and there are missing dependencies, you get a dialog that has the Ignore All on it.
(3,040 Views)
If there are dependencies missing, opening the VI is the way to go since Ignore All can be pressed.
I didn't know dependencies were missing, though, so I RMB to properties - and that's when it hangs.
The two VIs in this post are an example:
http://forums.ni.com/t5/LabVIEW/Memory-hog-timing-problems/m-p/2509758#M763908
I suppose since there are missing deps and conflicts, I can safely open and ignore. But I didn't - I right-clicked. And LV hung.
Just wondered what other folks do.
(3,032 Views)
What do you mean by "RMB"?
(3,021 Views)
Right Mouse Button: right-click
I had seen this shortcut on the forums before. I still go back and forth between FP/BD and front panel/block diagram.
(3,015 Views)
