scan from string error
I'm trying to extract xyz coordinates from a very large file.  However, every so often, there is a z coordinate with the phrase NO DATA instead of a value like so:
Is there any way to filter these out?
Any help would be much appreciated.  Here is a snapshot of my VI, it seems to be working for files without errors.
Message 1 of 13
(4,450 Views)
A brute force method:
Message 2 of 13
(4,437 Views)
You don't need to unbundle the error cluster in LabVIEW 2012.  The NOT function will take in the error cluster just fine.
Message 3 of 13
(4,432 Views)
Oh, yeah - oops. I tried wiring the error directly to the conditional and it didn't work (and the logic was backwards), so I dropped the unbundle in there.
Message 4 of 13
(4,429 Views)
How do I make the tunnel out of the for loop conditional?
Message 5 of 13
(4,420 Views)
It is new to LabVIEW 2012.  But you right-click on the tunnel and check Tunnel Mode->Conditional.
Message 6 of 13
(4,416 Views)
Is there any way to do it in the 2011 version?
Message 7 of 13
(4,413 Views)
Error case just feeds the array through unchanged.
Message 8 of 13
(4,410 Views)
Okay thanks I figured that out.  Doesn't that assigns the default value of 0 to the cluster when there is an error?  Is there any way to just omit the terms with errors?
Message 9 of 13
(4,402 Views)
That omits the terms with errors. In the Error case, the output array is not modified.
Message 10 of 13
(4,400 Views)
