Ring contol not working on remote panel
Hii,
I attached the test vi and html file. I am operating this VI remotely via NI MyRio. I can successfully change elements with property node while VI is running. But when I rejoin this remote panel, I can't see the changed elements. It always showed me the old elements when I rejoin the remote panel. I think its a bug. How can I solve this?
(1,533 Views)
Hi Parthsuhagiya,
any VI reboots with its default values.
After adding your changed elements during Running time, try to make the current values as default.
FrankenChino
(1,516 Views)
Hii FrankenChino,
Actually the Vi is in the running mode on real time target. It is not stopped. But I only opened the front panel remotely via browser for the second time of a running VI and I found this problem.
So the VI is continuously running on MyRio and I am operating its remote front panel via html with browser.
(1,499 Views)
Accepted by parthsuhagiya
Hi Parthsuhagiya,
I am not quite sure, this might be related to your case?
Reference:
https://www.ni.com/docs/en-US/bundle/labview/page/lvconcepts/viewing_fp_remote.html
(1,495 Views)
Hii FrankenChino,
Yes, It is exactly the information I am finding. Thanks for the help.
(1,455 Views)
