Ring control
how change check select item in ring control to my picture
(2,893 Views)
I believe that the explanation that you gave it's very reduced. Reading your post I can't understand your question. Try to explain it better.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,874 Views)
Are you referring to a Picture-Ring control?  (see image below).
If so, just copy / paste your image to the Front panel, then slide it into the ring control.  You can count up and add more pictures..
Message Edited by JoeLabView on 01-22-2008 01:55 PM
(2,866 Views)
