RingText.text property node not providing correct string
Hi all,
I'm having a strange issue with using a text ring.
Steps of execution:
1. Programmatically set the ring string and values using this property node:
2. Read RingText.Text property but gets back <0>
3. If I use another method by indexing the Strings[] property with current value, then the returned string is correct (matching the displayed text on the ring)
Here are some screenshots from my actual application:
method using RingText.Text property:
method using indexing String[] property:
Problem is that if I take out the UI component and do it in a blank VI, the ring text property works as expected.
Expected behaviour works if code is running on a simple VI:
Anyone came across this issue?
Thanks in advance 🙂
LV Version: LV2018 32-bit
Message 1 of 8
(2,502 Views)
Instead of a long set of pictures, attach a simplified version of your VI.
(Everything you describe seems to work fine in LabVIEW 2024, but we cannot really tell all your details)
Message 2 of 8
(2,488 Views)
That looks like a strict type def'd control (probably set to allow undefined strings)  I would expect the "<0>"
Message 3 of 8
(2,476 Views)
Add a query after step1 to see if the value gets set properly.
George Zou
Message 4 of 8
(2,466 Views)
I'm guessing that you've got a race condition; but I can't tell because you didn't post your code.
Message 5 of 8
(2,423 Views)
I did not see a black corner on the terminal and since he is writing a value of zero right after defining the strings&values property, and the string&value of the first item is ["A", 0], there is no reason to expect a <0> here, even if undefined string are allowed.
And yes, we cannot efficiently troubleshoot from pictures.
Message 6 of 8
(2,406 Views)
Accepted by J.CHEN
Hi all, thanks for your response.
I didn't post the code because getting the ringtext.text property works as expected in a simple VI but not in my application.
Which leads me to think about the race condition in my application that @paul_a_cardinale has mentioned.
I've found the issue to be the use of defer front panel update function in a separate loop causing UI to update at an independent rate. It's all working fine now.
Thanks again.
Message 7 of 8
(2,390 Views)
Thanks again.
Technically not a race condition, but yes, if you disable front panel updates you won't have any text to read from the controls ...
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(2,302 Views)
